Orbi WiFi 7 RBE973
Reply
How to Update POE-firmware on GS724TPP
TimesEnemy
I have a "GS724TPP: 24-Port Gigabit Hi-Power PoE+ Ethernet Smart Managed Pro Switch with 2 SFP Ports and Cloud Management" device running firmware 2.0.6.3.  There are a few discrepancies I would like addressed.
1) Under System > Management > Versions it shows Model Name: GS724TPP, Boot Version: 1.0.0.8, and Software Version: 2.0.6.3.  Should this Boot Version be the same as the Software Version?  If not, where do I find Boot Firmware updates?
2) Under System > PoE > Basic > PoE Configuration it shows Firmware Version: 1.8.0.5.  Should this PoE Firmware Version be the same as the above Software Version of 2.0.6.3?  If not, where do I find PoE Firmware updates?
3) For information purposes, under Maintenance > File Management > Dual Image > Dual Image Status it shows Image1 Ver: 2.0.6.3, Image2 Ver: 2.0.6.3, Current-active: image1, Next-active: image1.
I have searched the netgear.com website and can only find downloads for firmware which reference the image firmware, and am unable to find any boot or PoE specific firmware updates.
I have also searched this forum, and the closest thread I can find is the How to Update POE-firmware on M5300-POE thread, which does not apply to my GS724TPP.
Any help would be appreciated.  Thank you in advance!
Model: GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports
Message 1 of 2
schumaku
Guru
Re: How to Update POE-firmware on GS724TPP
No.
No.
Bootloader images would be made available along with a firmware distribution, and the update requirements (automatic update, or mandatory bootloader before the firmware installation would be documented. Mind your step: On older and more complex switches, always check the complete firmware update release notes, sometimes the notes of required bootloader updates went lost over time.
If PoE controller firmware updates are made available, these are typically included with the firmware images, uploaded and applied during the firmware update process - very customer friendly on these Smart Managed Pro switches.
You can also choose the firmware image (version) to become active after the boot, or in case return to the previous version. A nice feature.
-Kurt
PS. As we talk about a Smart Managed Pro switch, I'll ask a moderator to move the thread accordingly
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 655 views
  • 0 kudos
  • 2 in conversation
Announcements
