Orbi WiFi 7 RBE973
Reply
M4300-52G ProSAFE 4G24725T000C6 force speed 1G
scolson
Follower
Hi,
I have a stack of 6 M4300-52G
I try to force a port 1G in a 1G speed
when I try in cli I have the choise of 10mb 100mb and 10G
it's not a 10G port
you can see a print screen of the cli http://imgur.com/a/O0eKT
best regards,
Message 1 of 3
TCan
Re: M4300-52G ProSAFE 4G24725T000C6 force speed 1G
My guess would be that you don't have that as a choice as it is the default speed.
If you have a piece of equipment that you believe is 1Gb but connecting at a lower speed then I would try another cable as a faulty cable will cause this issue (assuming you have checked the settings on the other equipment and it isn't faulty). Also check there is no damage to the ethernet ports.
Message 2 of 3
ElaineP
NETGEAR Expert
Hi  scolson,
Under one interface, you can configure ‘speed auto 1000’ to force 1G speed. Due to M4300-52G still support 10G speed for other ports(port49,50,51,52), so under any interface, 10G speed can be seen. The switch displays all speeds for every interface.
NETGEAR Employee
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2548 views
  • 0 kudos
  • 3 in conversation
Announcements
