- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear switch: XS712T
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to connect 2 XS712T switches using both the fiberports to create a redundant 10GB link between these switches?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear switch: XS712T
It should creating be able to by creating a link agreggation with Netgear it's called LAG, you can find more about in the Software Administration Manual for this switch.
Remember that on this switch the 2 SFP+ slots are shared with 2 RJ45 sockets so plugging an optical module and cable in them will disable 2 RJ45 Ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much for your reply but what does this mean?
"It should creating be able to by creating a link agreggation"
- Mark as New
- Bookmark
- Subscribe
- Permalink
"English language difficult language master yoda says" 😉
I should have written instead: It should be possible, by creating by creating a link agreggation. With Netgear it's called LAG, you can find more about in the Software Administration Manual for this switch.
I won't tell you how exactly since there are some differences between models, revisions and firware & I don't have a smart managed switch at my fingertips (only fully managed) to check. For most switches there is a section in the Software Manual for your specific where you can see how it's supposed to be done on the UI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
