Orbi WiFi 7 RBE973
Reply
Network Switch
Gerchris
Tutor
Network Switch
I have a router from my provider on 10GB fiber. I want to connect a switch to the 10GB output from the router (the output is RSJ45) cable. Can anyone recommend a good router with input 10GB RSJ and minimum 10 ports output to the rest of the house. A bit lost with all the switch options.
thanks
Gerard
Message 1 of 6
Accepted Solutions
Re: Network Switch
10 Gb Internet isn't that common so there may not be many experts around here.
On the router front, try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Switches might be best discussed in the appropriate section:
Switches - NETGEAR Communities
To find out what Netgear makes, start here:
Network Switches For Home & Business | NETGEAR
Message 2 of 6
All Replies
Re: Network Switch
and
Message 2 of 6
Gerchris
Tutor
Re: Network Switch
Thanks I will try the switch community
Message 3 of 6
Gerchris
Tutor
10GB RSJ input and minimum of 10 ports output switch?
I have a router from my provider on 10GB fiber. I want to connect a switch to go to the 10GB output from the router (the output is RSJ45) cable to go to various points in the house. Can anyone recommend a good switch with input 10GB RSJ and minimum of 10 ports output to the rest of the house.
Message 4 of 6
Guru
Re: 10GB RSJ input and minimum of 10 ports output switch?
I fitted my network last year with these two switches, XS505M and GS110MX, working great. Un-managed and simple. There's a XS508 and XS512 and XS724 versions as well.
Message 5 of 6
Gerchris
Tutor
Many thx
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2380 views
  • 2 kudos
  • 3 in conversation
Announcements
