Orbi WiFi 7 RBE973
Reply
unable to get CAM Table from GSM7252PS
Simon1978
I'm unable to get the CAM Table via snmp(dot1dTpFdbTable). Other snmp queries work. public@vlan doesn't work either.
Model: GSM7252PS|ProSAFE 48+4 L2+ PoE Stackable Managed Switch
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: unable to get CAM Table from GSM7252PS
Hi Simon1978,
Welcome to the community! Smiley Happy
Please use MIB node 'dot1qtpFdbTable' instead.
EricZ
NETGEAR employee
Message 2 of 4
All Replies
Retired_Member
Not applicable
Hi Simon1978,
EricZ
NETGEAR employee
Message 2 of 4
Simon1978
Hi,
Thanks for the tip! The index-value in that table was confusing at first. But now I get it. The first value is the vlan number and the following numbers are the mac-address in decimal.
Simon
Message 3 of 4
Retired_Member
Not applicable
Hi Simon1978,
Correct!
With regard to resolve your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
EricZ
NETGEAR Employee
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1960 views
  • 0 kudos
  • 2 in conversation
Announcements
