Shop Meural NFT Display
Welcome to the Community Please Login
Reply
1st generation 27" white Meural Canvas no power
Joot95
Follower
Hello everyone.  I bougth a second hand 1st generation 27" white Meural Canvas. The seller did told me the unit will not turn off after he brought it out from storage.  Anyhow, does anyone have any idea what's wrong with the unit not powering on?
Model: MC227| Meural Canvas
Message 1 of 2
NG_Team
NETGEAR Moderator
Re: 1st generation 27" white Meural Canvas no power
It could be either the Meural no longer works (which may be indicated by the seller saying it wouldn't turn off for them), or the power adapter is dead.  If you know someone with a voltmeter they could check the power adapter, or you could purchase one of the multi-power adapters (make sure it has a connector end that fits the Meural) that supports the correct volatage and amperage pf the current adapter (this is printed on the adapter.)
Meural Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1402 views
  • 0 kudos
  • 2 in conversation
Announcements
Shop Meural NFT Displays
