Shop Meural NFT Display
Welcome to the Community Please Login
Reply
Canvas Says Offline
DrSharon
Guide
Re: Canvas Says Offline
Weirdly, my newer Canvas, bought 2022, is still connecting to the app, but my older 2nd generation one, bought 2017, stopped connecting like other people in this thread a week or so ago. Both are connected to the same wifi with strong signal.
Sharon
Message 51 of 73
Ak-Lex
Apprentice
Hi Sharon,
That’s actually good feedback, at least they can narrow down to possibly a firmware update on the older Meurals.
I haven’t heard of a solution yet.
Message 52 of 73
bparas
Guide
And after getting online yesterday, my canvas is back to being offline. So frustrating!
Message 53 of 73
Kenez
Initiate
Meural Lost Connectivity and says "Server Status Offline"
Hello,  My Meural has been working fine until yesterday when it lost connectivity.  It still says it is connected to my home network but to be sure I repeated the WiFi setup steps.  Both the app and website say "frame offline".  The frame itself says it is connected to my network but server status is "offline".  Could this mean that the problem is on Netgear's end?  Otherwise, anything I can try to restore connectivity?  See frame status below. Thanks.  IMG_4253.jpg
Message 54 of 73
Kimberley_M
Guide
Your Canvas Appears to be Offline
After 2 hours on the phone with support, I am ready to throw this thing out of the window! Original issue was that canvas was offline and now I'm stuck in an endless loop of the frame showing the "download QR code" and the motion no longer working. This is MC227, 2nd Generation.
1.) When I plug it in, I am brought to the Download QR screen
2.) Go to the Meural app on my phone
3.) Lower right, click Canvas
4.) I'm briefly brought to a screen that says 'synching your canvas', but then this goes to a screen that has my canvas name in upper left, and the message "Reconnect your Canvas to the WiFi Network. Your canvas is currently offline.  You may need to restart the WiFi service on your Canvas."
5.) I click "Restart WiFi"
6.) Instructions then say to "Wave down on the Canvas to pull up Canvas menu"  / Wave to WiFi / Wave to Restart WiFi.
Problem is once on the QR screen, the "wave" no longer works.
7.) So, within the app on this page, I have option to "Reset WiFi"
8.) Click Reset WiFi but more instructions regarding 'the wave' which I cannot do from the QR screen.
Thank you in advance for any help.  Love this product, but horrible support.
Message 55 of 73
georgepaul123
Initiate
Re: Meural Lost Connectivity and says "Server Status Offline"
Having the same issue with server connectivity. Can't find a resolution to it yet.
Message 56 of 73
DrSharon
Guide
My canvas re-connected to the Meural app on my iPhone last night, and this morning it has reconnected through the Netgear/Meural website on my laptop.
There is hope!
I hope it lasts...
Sharon
Message 57 of 73
Ak-Lex
Apprentice
Hi Sharon, thanks for sharing, I’ll try mine.
Message 58 of 73
Ak-Lex
Apprentice
That’s frustrating. Sharon was able to get hers online. I had hopes and came to try mine, did a reset and no luck. At this time I unplugged from the wall and only plug it in when trying for a connection.
I’m still offline
Message 59 of 73
Ak-Lex
Apprentice
Mine is still not connecting , shows server offline!
Message 60 of 73
joey301
Star
Sometimes, my frame will say offline, but later when I come back, what i had tried to upload is there. So, it seems they come online for a little while and then go offline.
Message 61 of 73
Willeee1
Tutor
I have two meural and they are both offline
Message 62 of 73
Eladspira
Initiate
I’m told to run factory reset. I’m afraid it will wipe out everything that’s now working.
What do I do?
Message 63 of 73
Djp441
Re: Your Canvas Appears to be Offline
I have the exact same problem. Just started. Any solution found yet?
Message 64 of 73
JKing3
Initiate
Not sure why the other thread is locked, but having the same issue. I have not bothered opening a support case yet as I think it will just be a waste of time. Unless someone has had better luck, please post.
Message 65 of 73
Guru
Re: Canvas Cassat-343 is online but app says its offline and won't connect
Message 66 of 73
nicolasjene
Serverstatus is always Offline
My Meural MC227 has the following problem: the serverstatus always says "offline" and it is not possible to connect using the app to the device. But the device gets a proper IP address and can be pinged. Anything I can do for fixing this issue?
Message 67 of 73
Guru
Re: Serverstatus is always Offline
NG seem to be aware of it and working on it?
https://community.netgear.com/t5/Meural-Canvas/Re-Canvas-Says-Offline/td-p/2399418/jump-to/first-unr...
You'll need to make contact with NG support and let them know if what your seeing and wait for them to get things corrected.
Good Luck.
Message 68 of 73
Kimberley_M
Guide
Canvas Offline Again
Mine somehow came back online on Monday (10/7).  Was able to send some new images over to the Canvas.  Now tonight (10/8) it is Offline again.
Any update Netgear???
Meural MC227
Message 69 of 73
Guru
Re: Canvas Offline Again
NG is aware of this and is working on a fix. Not time frame on final fix. So please be patient.
If you feel you need more help and information, please make contact with NG support.
Thank you.
Message 70 of 73
KevinLiT
NETGEAR Moderator
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.
We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Message 71 of 73
SirDale
Tutor
Can I get a refund on my Meural subscription?
Meural 1 no longer connects to anything and I've been unable to download new art for almost a month now.
How do we go about getting a refund on our membership costs?
Message 72 of 73
Guru
Re: Can I get a refund on my Meural subscription?
I'm not a member of netgear but I think the extended time they've had issues should warrant something. But again, not netgear.
Maybe @DarrenM would have some advice
Message 73 of 73
Top Contributors
Discussion stats
Announcements
Shop Meural NFT Displays
