- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Telstra MR1100 Nighthawk Data Usage Problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I know this topic has been raised before, but I cannot find an open discussion.
I have a Telstra MR1100/M1 modem, and since upgrading the firmware to NTG 9X50C_12.06.02.00, the display only shows, "Detecting Services."
I have tried rolling back the f irmware, but only get "Error16."
So, can anyone help or advise or direct me to a solution?
Mant thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have to say Thank You to all your guys for your patience to wait for us to resolve the issue with Telstra.
Regards
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Telstra MR1100 Nighthawk Data Usage Problems.
Telstra made some changes on their data usage server and broke the data usage display on M1. We are testing a fix for this issue and will have it addressd soon in the next couple of weeks. Thanks for your patient.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for responding.
I look forward to a solution.
Again, many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The "detecting service" error is where they are trying to detect the service to show the usage.
My system wasn't updating the usage so I factory reset it in the hopes of fixing it and now have the "detecting service" error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's now 31 December. No updates. Same problem: no data usage available & "Detecting service"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Niko_S, I agree!!
It may be a bigger problem, as I am useing a standby 4G modem, "Telstra 4GX USB+Wi-Fi Plus. It is also showing "Data usage information currently unavaiable."
This would suggest a Telstra problem, but until we are advised, we do not know!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is a telstra problem i have been advised by another member on the telstracrowdsupport forum. Its been going on for for nearly two months now, absolutely rediculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes from what I read, all they (telstracrowdsupportforum) say in responce is "contact customer service or the support centre."
This does not fix the issue!!
What next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully we’ll see something from them in January/February (I would think next week at absolute earliest).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi John P, Any news, it's now 16th January 2020!
Still the same problem!!
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Telstra is testing our new release. I expected the fix will be pushed out by us in the next one or two weeks. Please standby.
Thanks for your patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This data issue is why I have been attempting to get into the app.
But I can't find how to change the device password I set and forgot
I seem to be able to change every other Netgear password except this one
One support link states that there is a server error which is being fixed???
If you want to pay for support they advise that a one time option is available, but when you go to the selection area that option is not shown, leaving only the more expensive comprehensive options. to choose from.
My device still works fine but because this issue, can't know if data allowances are exceeded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you John, I'm "standing by!"
(But not holding my breath!!)
Paul
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, All,
Please be informed that firmware update is now available for MR1100 Telstra Variant. This is to address the data usage issue not available. Kindly check your devices for new firmware upgrade and let us know the result.
Firmware version is 12.06.08.00
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Data usage is now correct. However prepaid expiry is incorrectly showing as 0 days left on the physical display on the hotspot. It shows the correct expiry on the web admin page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick update on this.
For the expiry date, please wait for a while to see whether it can be corrected. I suspected that UI was not updated in time due to some timing issues.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
How long is a while?
It's showing correctly on the web page. It's the physical display on the unit that is showing the wrong value on my unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For Prepaid, please wait for 1 hour. The device will do data query every 60 minutes
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Updated firware to 12.06.08.00 as advised.
Now still showing"Detecting Serice."
So system appears not to have been fixed!!
I awaite a responce.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please check your device's PRI version is 05.05 after upgrade.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I find PRI settings??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Log in to WebUI and go to Settings -> Nighthawk M1 Status -> Device.
You can find the versions there.
Thanks
