Orbi WiFi 7 RBE973
Reply
AX4 AX3000 RAX40 Armor not Installing
rsatter
AX3000 WiFi Router (RAX40)
Firmware 1.0.4.102-1.0.1
Nighthawk app v2.20.1.12 running on iPhone 12 Pro Max iOS v 16.1
I brought out of storage this router to setup for a friend. It works great with one exception. Armor will not install.
When I did my set up of the router. I did a hard factor reset. Then ran the setup using Nighthawk app on an iPhone. I selected WIFI Router and did a manual setup. The setup ran fine with no problems.
I used a browser to check all settings. I did some testing to ensure the router worked. I then went to buy Armor however there is no Security options in Settings. I re-ran setup and I do see that after setup for the router completes there is no step to install Armor. I Googled but the only think I found was about Armor not showing up if set as an access point. It is not setup as an access point.
Any ideas?
Thanks
Message 1 of 4
Accepted Solutions
Re: AX4 AX3000 RAX40 Armor not Installing
That's not on the list of Armor supported routers:
Which products support NETGEAR Armor? | Answer | NETGEAR Support
Message 2 of 4
All Replies
Message 2 of 4
rsatter
The product page actually says it does support armor. It makes no mention of a V2. How do I let Netgear know to change the product page.
Message 3 of 4
The question is, which is correct? That page or the product page?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2280 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
