Orbi WiFi 7 RBE973
Reply
How to Activate NETGEAR Armor Using the Nighthawk App
Dustin_V
NETGEAR Employee Retired
Introducing NETGEAR Armor, advanced cybersecurity protection for all your devices on your Nighthawk AC2300 Router. See how easy it is to activate NETGEAR Armor in just a few steps with the Nighthawk App. Simply use Nighthawk app to activate NETGEAR Armor free trial on your supported router. Supported router models: R7000P AC2300 WiFi Router and R6900P AC1900 WiFi Router.
Check here for updates: https://www.netgear.com/landings/armor/
maxresdefault
Message 1 of 6
BlakeJ
Re: How to Activate NETGEAR Armor Using the Nighthawk App
I need to speak with someone for tech  support
Message 2 of 6
Quickbooks321
Thanks for sharing this article, I was so confused while activating Netgear but this article helps me a lot, require any help for accounting software Quickbooks we also provide help through Quickbooks Support Us on https://quickbook24x7.com/quickbooks-support-us/
Message 3 of 6
artsls
Hi,
I tried to activate Netgear Armor but there's no Security option in the Dashboard of the Nighthawk App installed. I'm using R7000P. Any idea what seems to be the problem?
Model: R7000|AC1900 Smart WIFI Router
Message 4 of 6
Christian_R
@artsls
Is you Nighthawk app on the latest version? is your R7000P on the latest firmware? Please try logging out and logging back in.
~Christian
Message 5 of 6
I am trying to subscribe to Armor but there are no offers listed under "my offers". My free trial has just run out on Nighthawk R7000P
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6099 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
