- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk r7000
I am looking for the Armor client for Mac OS to run on my MacBook Air. Can't seem to find the download, no URLs etc.
Is there a client for Armor to run on MacOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
Device specific downloads usually appear in the support pages for that model:
Visit the support pages:
Support | NETGEAR
That page should have any software, firmware and drivers for your device, if they exist.
Also try asking here:
NETGEAR Armor - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
@dlxxxc wrote:
Even the firmware versions are not downloadable.
They work just fine here.
R7000 Firmware Version 1.0.11.136 | Answer | NETGEAR Support
Getting messages file not found for every single firmware upgrade.
Something is amiss at your end. Hard to tell with no details about what you are using to download these files.
And av software is only mentioned fot ios and android
That's because, as explained, Netgear doesn't produce "av" software for particular models.
Support for stuff like Armor and parental controls is at the firmware level. A lot of the management then happens through an "app" for your mobile devices.
You seem to be a bit confused as to how Armor works. I see no sign that you have posted a question in the most appropriate place to get help with that:
Then there is this:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
the Armor / bitdefender license that covers different OS then ios and android...I can only find the mentioned apps. And not wjndows and mac os. And I am not talking about the Nighthawk client. Ghe AV client.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
@dlxxxc wrote:
You should be able to upgrade the firmware of the router from the nighthawk client. It states it is checking for new firmware and then says it up to date and it isn't as the latest version is
Unfortunately, that is not the most reliable way of checking the firmware.
The on-board check goes wrong for many reasons. One is that when Netgear implements major changes, like adding Armor to a device, it requires a two-step upgrade that the automated system can miss.
That is why we always ask people to tell us the version NUMBER.
Did you manage to download the firmware that you previously said is "not downloadable"?
I have now explained several times why you are wasting your time looking for Armor software for your router. It doesn't exist. Your existing firmware is that "software".
There really isn't much point in continuing the conversation if you insist on seeking something that doesn't exist.
Is there any reason why you haven't, as far as I can see, visited the section here that supports Armor?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
I am not looking for armor software for my router. You are right. It is useless I am looking for the armor bitdefender av software for mac os. I know next time i will not be asking it on here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
Bitdefender Total Security Special Offer
Search - NETGEAR Communities – armor bitdefender mac
What features does NETGEAR Armor offer? | Answer | NETGEAR Support
What is Bitdefender Security? | Answer | NETGEAR Support
How do I install Bitdefender Security on-the-go protection on my devices? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk r7000
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
