× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
KVR400X64SC3A/1G 1GB
owentje1
I have tried two of these in my NV+. The result was a non booting NV+. This memorymodule should be removed from the compatibility list. The user 'geekstarpilot' experienced also the same problem with this module. On the internet are more posts regarding this module using the Readynas DUO (also with problems).
So I do not recommend using this (I guess the current revision is somehow a bit different compared to the ones which other users are using with success)
Message 1 of 3
Gnagman
Re: KVR400X64SC3A/1G 1GB
Have the same problem, the KVR400x64SC3A/1G does NOT work. Remove it from the compatibility list.
Message 2 of 3
Optik
Just encounted the very much earlier comments about this. By accident found positive views about this memory module (well before I found this info) - so installed on NAS Duo 2 x Tbye RAID 4.1.7 setup - has functioned perfectly from the off - now been running continuously for 5 months. Don't know the cause of the problem with higher spec NASs.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2832 views
  • 0 kudos
  • 3 in conversation
Announcements
