- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Moving from single redundancy to dual - RNDU6000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am runnning a ReadyNAS Ultra 6 (RNDU6000) on OS v6.10.7
I have 5x 8TB disks in the bays and it's currently setup as X-RAID/RAID 5.
If I want to add a 6th disk as dual redundancy, how do I best achieve this?
I recall reading about changing to Flex-RAID first and then adding a final disk and choosing how it's used.
Is this correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Moving from single redundancy to dual - RNDU6000
Is this correct?
Yes. You will need to ensure that this disk is as large as the biggest one in the array (and there need to be 3 disks already in the array of that size).
After adding the new disk for redundancy, you should be able to switch back to X-RAID if you like.
Once you are using RAID-5, future expansion will require upgrading 4 of the disks to the new larger size.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good, thanks Stephen.
If I want to enlarge my storage in the future, are you saying that I would need to upgrade at least 4 of the disks?
I'm ok with that, but in that case, what would the steps be?
e.g. If I move from 8TB drives to 16TB drives in the future, would I swap out one at a time and after each swap, let the re-sync happen, getting my extra storage after the 4th 16TB has been swapped in?
You are indeed the forum guru, thanks for answering all my questions!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly.
