× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN 102 RAID 1 reconstruction takes ages with NO DATA
tytou
I've a readynas RN102 with 2 3TB hdd in it, configured in RAID 1.
I have NO (in fact only very few small files) stored on it (max less than 10MB). When I test hot swap to reconstruct the RAID from one disk to copy data to the other it takes ages (several hours!!! 8, 9 hours!). Is it normal? I was supposing that time for reconstruction was depending on the data size, not the HDD size which in my cas is empty. If it is not normal, do you have any idea why it is so long ? Thanks for you help.
Message 1 of 7
cpu8088
Virtuoso
Re: RN 102 RAID 1 reconstruction takes ages with NO DATA
8 hours for 3tb resync is normal
if u use a faster nas 312 the duration can be shortened
Message 2 of 7
mdgm-ntgr
NETGEAR Employee Retired
The disks have to be synced sector by sector to rebuild the RAID.
Message 3 of 7
fordem
Mentor
It is normal, it is dictated by disk size not by space utilized - RAID1 reconstruction is normally done by a block-by-block copy.
Message 4 of 7
JennC
Hello tytou,
You only need RAID resync if there is a drive failure and that you have to replace it. Both file system check and RAID resync are a bit slow and read entire partition that can take a while, these things slow down more too when you use weaker processer like the ReadyNAS 100 series that has 512mb memory.
Here's an article that will help about expansion in case you need it in the future: http://kb.netgear.com/app/answers/detail/a_id/23133/related/1
Message 5 of 7
tytou
Many thanks for you so promtpt answers.
Kindest regards to the community.
Tytou
Message 6 of 7
JennC
Helo tytou,
Feel free to post questions, ideas, suggestions or anything about your NAS.
Welcome to the community!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4679 views
  • 2 kudos
  • 5 in conversation
Announcements
