× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104 stuck in Boot Menu
dcourt
Hi
I tool at look at my RN104 this morning as I couldnt access a file from it... I havent done any FW upgrades or anything, and it was working normally yesterday..
Today -
Looking at the NAS:
- Power Light = Blinking/Flashing
- Disk Lights = Off
- Act = On
- Display = Boot Menu
- Pressing Backup Button = displays Boot Menu - Normal
- Pressing Backup Button again doesn't do anything once Normal appears.
I have tried booting with and without discs - no difference.  The NAS is also not showing as discoverable via RAIDar.
Any thoughts please?
cheers
Message 1 of 4
Sandshark
Sensei
Re: RN104 stuck in Boot Menu
Your UBOOT is probably corrupt and a USB recovery should fix it unless the memory itself (not just the content) is bad.
Message 2 of 4
dcourt
I have tried a USB recovery. I ve created a USB stick, and booted the NAS from the stick.  It completes, then powers off - but when I power on the NAS again - same symptoms 😞
is there any way I can get to the memory to reseat it, or is it hard wired to a board?
Message 3 of 4
Guru
Memory (flash and ram) are soldered to the board.
Have you tried powering down, removing the disks (labeling by slot), and then powering up?  See if the NAS reports a "no disks" status.
Normally the NAS will boot from disk 1, and there are situations where an issue with disk 1 will result in a failure to boot.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 802 views
  • 0 kudos
  • 3 in conversation
Announcements
