- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I keep loosing credential access from pc to NAS. os reinstall only works
- Mark as New
- Bookmark
- Subscribe
- Permalink
NAS r104
keep loosing access from pc
if I reset os reinstall it works but I loose it 2 times a day.
It is frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I keep loosing credential access from pc to NAS. os reinstall only works
@carlocki wrote:
NAS r104
It is frustrating.
That is really strange. Are you sure the issue isn't on the PC end?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am thinking the same. do I have to change forums?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@carlocki wrote:
sometimes it works like this
Sorry, but I am not seeing what is wrong in this picture.
When you say you are losing - are you getting a password error, or is the NAS just not responding?
Have you tried restarting it (instead of doing an OS reinstall)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
password error in all mapped link
for example itunes does not open correctly
- Mark as New
- Bookmark
- Subscribe
- Permalink
cheked now. Sometimes it works sometimes not. independently from pc and nas restart.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible that you are trying to use two credentials for the same NAS from the same PC (with Explorer)?
Windows doesn't allow that - changing to a different credential will fail unless you do a net use * /del /y and then reconnect.
BTW, there is a trick if you need to use two credentials for some reason. The PC treats the NAS hostname and the NAS IP address as two different machines. So you can use one credential with the hostname, and a different credential with the IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And if you have saved one set of credentials in the Windows credential manager, Windows may be logging you into the NAS with those credentials without you even realizing it, thus "locking out" any other. If you use both the admin and a non-admin account via SMB, that can easily be the case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
now it seems to work again.
do not ask me why. let me try a couple of days.
If i work and It does not work It will be a nice problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
now, the day after, I cannot access...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does https://nas-ip-address/admin work? (substituting the real IP address)?
Does opening CMD and entering net use * /del /y and then trying again help?
How about rebooting the PC?
If not, what specific error are you getting?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes but i access with mail and password
that is
when i restart the folders connection with nas give me "
the connection was not restored
- Mark as New
- Bookmark
- Subscribe
- Permalink
You typed the command incorrectly in your screenshot (net usenet use).
- Mark as New
- Bookmark
- Subscribe
- Permalink
if I type it correctly i have
Errore di sistema 85.
Nome di dispositivo locale già in uso.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
done
- Mark as New
- Bookmark
- Subscribe
- Permalink
it seems like pc (rebooting or not) sometimes for a sort time do not accept any password. this happened since the first os reinstall in the NAS
- Mark as New
- Bookmark
- Subscribe
- Permalink
no way, impossible to access without a os reinstal on the nas everytime
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
here?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Microsoft Windows [Versione 10.0.19044.2130]
(c) Microsoft Corporation. Tutti i diritti sono riservati.C:\Users\Carlo>net use a: \\192.1xx.1xx.1xx\data /user:admin @xxxxxxxxxx
Errore di sistema 1219.Le connessioni multiple a un server o a una risorsa condivisa da parte dello stesso utente, utilizzando più di un nome utente, non sono consentite. Interrompere tutte le connessioni precedenti al server o alla risorsa condivisa e riprovare.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@carlocki wrote:
here?
Ok, it looks like you have configured a static IP address on the NAS.
Normally I recommend using DHCP for the NAS, and reserving the IP address in the router instead (most routers have that feature).
One thing you do need to be careful about with a static address - you need to make sure that the router doesn't assign 192.168.1.100 to another device on the network. That creates duplicate addresses, which can result in a lot of strange problems.
Have you also set up the router to make sure that the DHCP range doesn't include 192.168.1.100? (Or any other static addresses that you might have assigned)? If not, you should either do that, or instead reserve 192.168.1.100 for the NAS in the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This error is a PC issue.
Windows only allows you to access the NAS using one username/password. If the PC already has a connection to the NAS using a different username/password, you will get this error. The net use /del /y normally closes all those connections - which is why I always tell people to use that command before trying to map a NAS share to a drive letter. But sometimes that command doesn't prevent the 1219 error.
You can also try substituting the NAS hostname for the IP address - Windows treats the hostname as a different device than the IP address.
Note that rebooting the PC will close all the connections, but there might be something happening at startup to reopen one.
