× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN214 compability with EDA500 ?
t0mki
I can not find information is RN214 compatible with the EDA500 enclosure?
I found only information that the EDA500 fits the 300/500 series.
So, what can be connected to the esata port in the RN214 model?
Model: RN21400|ReadyNAS 214 Series 4-Bay (Diskless)
Message 1 of 8
Accepted Solutions
Marc_V
NETGEAR Employee Retired
Re: RN214 compability with EDA500 ?
Hi @t0mki
Welcome to the Community!
RN214's Max disk capacity is only 4 and no other option to add an expansion like the EDA500 which limits it capacity to only 48TB on 12TB disks, possibly because it only runs on ARM processor unlike other series (300/400/500/600/700) which are all x86 that will be able to handle higher capacity. Performance of the RN200 might be degraded if it handles a higher volume capacity or higher number of disks than it's intended to.
You can always connect eSATA external disks on the RN200 series model.
Hope this helps!
Regards
Message 2 of 8
All Replies
Marc_V
Hi @t0mki
Hope this helps!
Regards
Message 2 of 8
t0mki
In summary: RN214 does not have a eSATA port multiplier .
So I can connect only 1 disk ?
Message 3 of 8
schumaku
Guru
No, it does not support the EDA500 (which is built around a eSATA port multiplier) mainly for perfromance reasons.
The eSATA port allows to connect an eSATA enclosure with a single disk.
Message 4 of 8
Marc_V
Hi @t0mki
Yes it will get you 1 disk connected. Connecting a multiplier and connecting multiple disks might result with no power or not getting detected.
Regards
Message 5 of 8
Sandshark
Sensei
And you do realize that the EDA500 is a discontinued product, right?  I have found that other eSATA port multiplier enclosures are compatible with NASes compatible with the EDA500, though.
Message 6 of 8
t0mki
I know, but I can still buy EDA500 in Poland.
Message 7 of 8
Marc_V
Hi @t0mki
IMO, It might be better to buy another NAS for your expansion needs,
Regards
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1260 views
  • 0 kudos
  • 4 in conversation
Announcements
