Orbi WiFi 7 RBE973
Reply
RN314 & WinNUT
claynz
RN314 & WinNUT
Basically I have a Cyberpower UPS connected to my PC via a USB cable and the UPS is not a network UPS.
I would like to use WinNUT to configre the NAS but can not get it to work correctly without errors
UPS [UPS@192.168.1.6]: connect failed: Connection failure: Unknown error
Level NOTICE 10/14/2021 15:27:34 UPS UPS@192.168.1.6 is unavailable
the settings that was suggested to use are
# MONITOR <system> <powervalue> <username> <password> ("master"|"slave")
MONITOR UPS@192.168.1.6 1 monuser pass slave
# MINSUPPLIES <num>
MINSUPPLIES 1
# NOTIFYCMD <command>
NOTIFYCMD "\"c:\\Program Files\\WinNUT\\alertPopup.exe\""
# POLLFREQ <n>
POLLFREQ 5
# POLLFREQALERT <n>
POLLFREQALERT 5
# HOSTSYNC - How long upsmon will wait before giving up on another upsmon
HOSTSYNC 15
# DEADTIME - Interval to wait before declaring a stale ups "dead"
DEADTIME 15
# NOTIFYMSG - change messages sent by upsmon when certain events occur
NOTIFYMSG ONLINE "UPS %s is getting line power"
NOTIFYMSG ONBATT "Someone pulled the plug on %s"
NOTIFYMSG LOWBATT "UPS has a low battery"
NOTIFYMSG SHUTDOWN "The system is being shutdown"
# NOTIFYFLAG - change behavior of upsmon when NOTIFY events occur
NOTIFYFLAG ONLINE EXEC
NOTIFYFLAG ONBATT EXEC
NOTIFYFLAG LOWBATT EXEC
NOTIFYFLAG SHUTDOWN EXEC
# RBWARNTIME - replace battery warning time in seconds
RBWARNTIME 43200
# NOCOMMWARNTIME - no communications warning time in seconds
NOCOMMWARNTIME 300
# FINALDELAY - last sleep interval before shutting down the system
FINALDELAY 5
Have I missed out something? do I need a USB cable plugged in to the UPS and NAS?
Any help would be appreacited and when it comes to these sort of things I'm a dummy...
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 3
Guru
Re: RN314 & WinNUT
Have you tried this the other way around (connecting the UPS to the NAS, and enabling remote network monitoring on the NAS)?  Then use WinNUT to shut down the PC when the UPS battery drains?
I don't think the NAS is running a upsd server when the UPS is not connected to the NAS itself.
Message 2 of 3
Sandshark
Sensei
Re: RN314 & WinNUT
OK, so are these the settings on the PC or the NAS?  The setting above is for monitoring a remote UPS at 192.168.6.1.  But you should not be going in and doing that directly on the NAS, and the rest looks like it's for the the PC.  If the UPS is on the PC, the PC installation has to be the server and use the GUI capability to monitor a remote NAS and give the IP address and password.
But I agree with @StephenB that you might have better luck with the UPS on the NAS and the PC monitoring it, mostly because the version of NUT in the NAS is rather old and may not be able to talk to a newer version of WinNUT.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1018 views
  • 0 kudos
  • 3 in conversation
Announcements
