- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 6.10.3 OneDrive bidirectional sync problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have RNDU6000 running 6.10.3. I enabled bidirectional sync to OneDrive and found this issue:
* when I delete a file in OneDrive, it is deleted in NAS
* when I delete a file in NAS, it is NOT deleted in OneDrive
How can I fix this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi poko2121,
It will be best for you to contact our support team. There is a fix that they can apply to your NAS that can probably fix the issue.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 6.10.3 OneDrive bidirectional sync problem
Hi mrQQ,
Have you tried leaving the NAS from OneDrive then rejoining it?
Do you also experience the same issue if you select Upload local storage changes only for the sync direction?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try those.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem. I've tried leaving and rejoining, did not help. Also the same issue is present when Upload local storage changes only is selected. It is happenning pretty consistently.
This is what I have in the log when I delete a file locally and it does not get deleted from onedrive:
Jul 05 23:50:30 ReadyNAS ng-csd[18056]: Failed to get sync action. Error #12: File not found: <path here>
Jul 05 23:50:30 ReadyNAS ng-csd[18056]: E0705 23:50:30.423131 18056 SyncUpsyncFile.cpp:243] Failed to get sync action. Error #12: File not found: <path here>
This worked well before so the bug may have been introduced by a recent firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi zbs,
Can you provide me the complete system logs of your NAS? You may upload it to a file-sharing site then send me the download link via private message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi poko2121,
- Mark as New
- Bookmark
- Subscribe
- Permalink
oh great, how can i get in touch with them
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi poko2121,
You may open a support ticket by logging in to the myNETGEAR portal (my.netgear.com).
- Mark as New
- Bookmark
- Subscribe
- Permalink
JohnCM, I'm not sure how to reply privately but the site it not allowing me to create a support ticket. Is the patch something I can do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi poko2121,
If your device is out of support warranty, you will need to purchase a support contract before you can open a support ticket.
Can you send first the serial number of your ReadyNAS via private message? You can send a private message by clicking the envelope icon on the upper right corner of the page.
Regards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
