Orbi WiFi 7 RBE973
Reply
ReadyNas RN2304 Using Large capacity SSD (16TB) connected to USB
Obiwan_
Apprentice
I have four RN2304s with max capacity on one of 28TB. I have been trying to set up backups using attached USB drives. So far I have used mechanical USB drives to capacity of 5TB without any problem. I purchased some 16TB SSD usb drives and the NAS would not mount them. I tried various formats (NTFS, exFat, etc) without success. I then started reducing the size of the drive and reached 1.25TB (MBR:NTFS) and it sees the drive. Has anyone had success with larger SSDs? Any suggestions?
Thanks
Message 1 of 7
Sandshark
Sensei
Re: ReadyNas RN2304 Using Large capacity SSD (16TB) connected to USB
The ReadyNAS OS does not support ExFAT, so don't keep trying that.  It should support GPT/NTFS without regard to it being an SSD or mechanical hard drive.  But it does not support a drive having a GPT protective partition.  When it does show up, what happens if you try to reformat with the NAS?
Message 2 of 7
Guru
What did you buy?
The largest Crucial and Samsung external SSDs are 4 TB. I am thinking you might have gotten a scam drive (not having the capacity it claims).
Message 3 of 7
Obiwan_
Apprentice
The drives are available in various sizes 8, 16, 16 GB. See jpeg attached.
Message 4 of 7
Obiwan_
Apprentice
I pulled it apart and it is a scam. inside 64 gb micro  ssd Son of a B- - - - H !!!!
One of the venders is wrapango.com
Message 5 of 7
Sandshark
Sensei
It would certainly be possible to cram a few M.2 SSDs into one external case, together with the necessary circuitry to concatenate them, but it would be quite expensive.  Sorry you had to find out the hard way that one is too good to be true and I hope you can get your money back.
Message 6 of 7
npandit
Hello @Obiwan_
Could you please check the Snapshot and backup capacity your NAS is having.
Also, Please disable Quota, audit, and File search, then reboot the NAS and check if you are facing the same issue.
Have a lovely day,
Niveditapa
Netgear Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1771 views
  • 4 kudos
  • 4 in conversation
Announcements
