paul_j_ghosh
Mar 21, 2012Aspirant
readynas nv+ green disk LED no longer lights up
One of the green disk LED no longer lights up on a readynas NV+. What are my options? Disk is fine and present in that slot.
- ReadySECUREApprenticeUsually this is an indication of a disk failure, if the disk appears and shows healthy then I would want to check that with more than just those two indicators.
Do you have RAIDar on a machine that is local to the NAS?
If you do, make sure to check the indicators in RAIDar.
I would also go to Status > Logs > Download All Logs (in the upper right hand corner). Once downloaded you can extract them and look at the Disk_smart logs, there should be a bunch of them that have dates (depending on how long the NAS has been online) and then one that just reads "disk_smart.log". The last mentioned would be the one I would want to check for any reallocated sectors or ATA errors. Please post back what you find.
If you are not sure how to interpret the logs, you can send them to me or post them here for further analysis. - paul_j_ghoshAspirantI logged into the frontview site and took a look at the disks - all are in good shape. I also clicked on SMART and took a look at the various metrics present. None seemed out of order. My assumption is that the SMART screen for the disk would show errors if there were issues - currently it says OK. I cannot run RAIDar at present since I am not at home - however, I do have shell access and I just took a look at the following log:
/var/log/frontview/disk_smart_2012_03_18.log
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
That is the message for:
***** Disk SMART log for channel X [hdc] *****
where X is 1 through 4.
Where else should I be looking? - paul_j_ghoshAspirantThe Seagate ST2000DL003-9VT166 seem unreliable. The drive in question has 359 hours. The LED went off. I pulled out the drive. Hot event detected. Inserted the drive back in. RAID resync started and the light is now flashing. So, it is not an LED issue but rather a drive issue as pointed out earlier. Why was an alert not provided? Which log should I be looking at to find out what happened? Why is it now doing a resync and not complaining about a bad drive? Why has it not complained about the drive at all ever?
- mdgm-ntgrNETGEAR Employee RetiredWhat's the disk_smart log like for that drive? Please post the full log for that drive (omitting the drive serial number). The 2012_03_18 one should be fine (or the last one before you removed and readded the drive)
The NAS runs short SMART tests daily and on boot. SMART won't always detect a problem disk. Testing the drive using SeaTools running both the short and long tests would be the way to go. - paul_j_ghoshAspirant
***** Disk SMART log for channel 1 [hdc] *****
smartctl version 5.36 [sparc64-unknown-linux-gnu] Copyright (C) 2002-6 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: ST2000DL003-9VT166
Serial Number: XXXXXXXX
Firmware Version: CC3C
User Capacity: 2,000,398,934,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Not recognized. Minor revision code: 0x29
Local Time is: Sun Mar 18 06:47:03 2012 CDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 623) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 76058336
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 6
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 060 060 030 Pre-fail Always - 1238193
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 273
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 6
183 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
184 Unknown_Attribute 0x0032 100 100 099 Old_age Always - 0
187 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
188 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
189 Unknown_Attribute 0x003a 100 100 000 Old_age Always - 0
190 Unknown_Attribute 0x0022 069 067 045 Old_age Always - 554893343
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 5
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 6
194 Temperature_Celsius 0x0022 031 040 000 Old_age Always - 31 (Lifetime Min/Max 0/19)
195 Hardware_ECC_Recovered 0x001a 029 015 000 Old_age Always - 76058336
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 234715667759377
241 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 3502143553
242 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 2481207792
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay. - paul_j_ghoshAspirantAfter the sync completed this morning the LED is off again. No SMART errors. I guess I have to get a drive enclosure and test the harddrive... Any other thoughts?
- PapaBear1ApprenticeIt is best to test the drive while it is connected directly to the motherboard of a PC. Most of the testing applications will not work fully on a drive connected via an enclosure connected to USB.
Another question that was asked but I have not seen an answer to is what are the indicators like when you open RAIDar? In the column for disks you should have 4 indicators and the ones for each installed drive should be green. - paul_j_ghoshAspirantOuch - I don't own a regular PC with a motherboard. Only Windows laptops and a Macbook Air.
All four are green on RAIDar and the first is off on the NAS itself. There must be some log somewhere which says something about the LED being off on the NAS display if indeed it is intentional and not a faulty LED. - mdgm-ntgrNETGEAR Employee RetiredIn the logs what does it indicate for that disk in enclosure.log?
Sounds like a faulty LED.
When did you purchase this NV+? Was it purchased brand new on/after Aug 21, 2007? - paul_j_ghoshAspirantThe NAS was purchased used about two months ago to join another that I had bought new several years ago. No labels present so I cannot tell you any sort of date. What is important about Aug 21, 2007?
temp!!1!!status=ok::descr=30.0C/86.0F::expected=0-60C/32-140F
fan!!1!!status=ok::descr=2083RPM
ups!!1!!status=not_present::descr=Not present
volume!!1!!status=ok::descr=Volume C: RAID Level X, Redundant; 1352 GB (24%) of 5538 GB used
disk!!1!!status=ok::descr=Channel 1: Seagate ST2000DL003-9VT166 1863 GB, 31C/87F
disk!!2!!status=ok::descr=Channel 2: Seagate ST2000DL003-9VT166 1863 GB, 33C/91F
disk!!3!!status=ok::descr=Channel 3: Seagate ST2000DL003-9VT166 1863 GB, 32C/89F
disk!!4!!status=ok::descr=Channel 4: Seagate ST2000DL003-9VT166 1863 GB, 31C/87F
model!!0!!mode=pro::descr=ReadyNAS NV+::arch=nsp
