× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Connection issues XR500
Evanfly
Guide
Re: Connection issues XR500
I'm back on f/w
XR500 V2.3.2.56
there is no lease obtained/expired information in connection status.all thats there is:
Connection Time00:03:49
Connection Statusconnected
NegotiationSuccess
AuthenticationSuccess
IP Address
Subnet Mask255.255.255.255
I've blanked the ip part but it is connected
Message 26 of 41
Netduma-Fraser
NetDuma Partner
What device are you viewing it on as I can definitely see it on a PC.
Message 27 of 41
Evanfly
Guide
I'm on my laptop
Message 28 of 41
Evanfly
Guide
I've just flashed it back to the beta firmware but there is still no info you required?
Message 29 of 41
Netduma-Fraser
NetDuma Partner
Could you provide a screenshot of the page please? You can omit the IP if preferred.
Message 30 of 41
Evanfly
Guide
Message 31 of 41
Netduma-Fraser
NetDuma Partner
Okay understood thank you. I believe it is the DHCP bug I mentioned then, do you have another router you could put between the modem and XR that could take some of the pressure off the XR until it is resolved?
Message 32 of 41
Evanfly
Guide
I do but how do I set it up please
Message 33 of 41
Evanfly
Guide
In regards to the bug is there a time frame regarding the fix?thanks
Message 34 of 41
Netduma-Fraser
NetDuma Partner
Connect your other router direct to the modem and then connect the XR to that router. Copy the WAN IP from the XR System Information page and input that into the other router DMZ.
Message 35 of 41
Evanfly
Guide
Thank you again for your assistance
Message 36 of 41
Evanfly
Guide
Just checking if the bug has been resolved as I haven't used the router since the problem.
Message 37 of 41
Netduma-Fraser
NetDuma Partner
NG devs have put out a debug firmware for people to use and gather information when they have the issue so assuming they get enough info they should be able to fix it soon.
Message 38 of 41
Evanfly
Guide
Ok thank you for the update fingers crossed it gets sorted soon.
Message 39 of 41
Evanfly
Guide
Any updates?
Message 40 of 41
Netduma-Liam
NetDuma Partner
We don't have a confirmed solution yet, but there is a new beta firmware version that's looking pretty good so I'd suggest you try that.
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/...
Make sure you perform a factory reset after the upgrade to ensure any low-level code from the previous firmware is cleared out.
Message 41 of 41
Discussion stats
  • 40 replies
  • 4070 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
