×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Losing Internet connection
BanditMask
My new router consistently loses connection to my ISP cable modem.
Logs
[DumaOS] DHCP lease change., Thursday, March 07, 2019 17:15:56
[DumaOS] DHCP new event., Thursday, March 07, 2019 17:15:56
I've read through posts, disabled Xbox Instant on, hard set IPs, reduced range 200-254
any fix, it seems to be a reoccurring issue among others on the forum. I'm using the latest firmware
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 14
Guru
Re: Losing Internet connection
What FW is currently loaded?
You might revert to v32
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 14
BanditMask
V2.3.2.40
Arris TM1602
Message 3 of 14
Netduma-Fraser
NetDuma Partner
You said you set static/reserved IPs was this just for your LAN devices? If so I would recommend doing it in Settings > Internet Setup.
Message 4 of 14
BanditMask
I don't have this option. No access to the modem.
My Nighthawk R6400 never had this issue.
Message 5 of 14
Netduma-Fraser
NetDuma Partner
Not on the modem I mean on the router. Routerlogin.net > Settings > Internet Setup, switch from dynamic to static
Message 6 of 14
BanditMask
Can you do that if the ISP is using DHCP? Wouldn't you need to have them create and assign a static address for that to work?
in any case, I've had them give me a brand new modem of a different manufacturer. Let's see if that changes anything.
Message 7 of 14
Netduma-Fraser
NetDuma Partner
Yes you can, no it can be done from the router without having to do that.
Okay great, keep us updated with what happens!
Message 8 of 14
BanditMask
Still losing Internet connection, seems that the intervals in between are longer now though. As to your suggestion, how do I know the static IP to set? According to my ISP only upgrading to a business account has the ability for static IP. Is there another way?
Message 9 of 14
Guru
I would revert to v32 FW version on the XR router.
Most ISPs will not allow for static WAN IPs to be set unless you pay for it or comes on there Business class packages.
Can you try a different ISP modem? Arris TMs are not the greatest.
Message 10 of 14
Netduma_Jack
NetDuma Partner
Try going back one firmware as Furry suggested, and then see if it's better:
https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
Message 11 of 14
BanditMask
Downgrading the firmware seems to have worked. I'll post again if it restarts.
Since it happened with two different modems by different manufacturers, any idea if this might be fixed in a later version?
I'd hate to never be able to update my firmware again.
Message 12 of 14
Guru
v40 seems to have problems with some users. I presume NG will be making changes.
Your ok to run v32 if it works for you and it provides all you need. You don't always have to update. Unless there maybe some security concerns.
Message 13 of 14
Netduma_Jack
NetDuma Partner
I expect the version after .40 will be more stable, so you should be ok to upgrade to it once it's released.
Message 14 of 14
Discussion stats
  • 13 replies
  • 2211 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
