- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using the Nighthawk XR 500 in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using the Nighthawk XR 500 in AP mode
When in AP mode, ALL router features are disabled on the XR500. Only wireless is left running.
You can do the following:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No that is not possible.
Your best solution if you need to supply internet and wifi access with the home #1 would be to use the ISP modem and wifi there, then use its DMZ for the XR router at home #2. You can leave the wifi enabled at the ISP modem in your case since the distance between the modem and XR router are far.
Ok now that you posted distance. If your getting wifi via wifi beam, then I believe this would work with the XR in router mode. However having all this wifi devices and beam in the middle, you may see odd or bad gaming performances in this kind of configuration. Having different methods to get from one point to another while data traverses these could pose a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can and no it would not expose #1 to any problems. DMZ is only for the XR router and since it would be working in router mode while in the DMZ, the XRs firewall will be active and preventing problems from appearing on your system. Just like if it was connected to any modem directly. You'll be fine using the DMZ.
@Murllin wrote:
The Nanobeams are AC Antennas that operate at 5ghz. but I have ubiquities latest firmware that unlocks the higher frequencies so they operate around 5800-5900 mhz. Too high to interfere with the wifi on the routers as far as I can tell. Would setting up DMZ on the ISP router allow my XR to run as a router too? And would that open up house #1s internet to be exposed to the internet? I put a little jpeg of a "professional" diagram of my set up.
