- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR500 DHCP issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR500 DHCP issue
Yup it workewd for about 2 weeks then same issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just factory reset the router and still same problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
any further updates? it def is a RAM problem i think
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It really is ridiculous for a top of the line router.
I have found that disabling 5ghz wifi seems to improve the ram usage on the router with less crashes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Netduma-Fraser If you recall from further up in this thread I started, this doesn't work. Static/Reserved IPS are still subject to issues when the DHCP lease time expires. This happens even if you set the IPs to outside the DHCP range.
I gave up on Netgear and this router after waiting for nearly a year for a firmware update. The router is currently at the garbage dump. The XR500 was the first Netgear router I've purchased, but it will be my last until it can be proven that Netgear is more mindful of basic functionality. The Asus RT-AX88U blows this router out of the water both hardware and firmware wise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tekonsite thanks for the understanding. That's partly my theory as well If you take that out of bridge mode and set the IP and use it in the DMZ then it may resolve the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. Power cycled the Arris Modem
2. Power cycled XR500
3. Logged into both to check, all good
4. When logged into Arris Modem in bridge mode I noticed the 4 ports have energy efficiency turned on. I turned that off on the port the XR500 is plugged into.
5. DHCP has been stable so far for two days now.
I will further update at the end of the week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just wanted to confirm the new .108 beta resolves the dhcp issues for my XR500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Sorry been late to feedback the DHCP issue you have now.
Please kindly install this debug firmware - https://ntgr-my.sharepoint.com/:u:/g/personal/tichang_netgear_com/Ecek7S3fUjZHmGi11s60rNQB1eZUv5HHh-...
And follow the steps to get the debug logs for our analysis if you still can see the issue.
- Plugin a USB device to DUT. Open debug page: http://192.168.1.1/debug.htm
- Select the checkbox “Enable WAN/LAN Packet Capture”.
- Choose “USB Device” in store location.
- Click "Start Capture" button.
- Once issue occurs, press the Button “Save debug log”.
- Send the log to us.
Please make sure in the capture file in \\192.168.1.1\USB_Storage\Capture, there are lan.pcap and wan.pcap file inside.
I can see some users disable the power saving in the ISP modem, this is a good approach to idenify the issue. The Ethernet switch chipset may have some issue to handle the power saving mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the router now crash two times this week. Today it was very strange, I turned on my Galaxy Note 20 and the internet looked to be fine and then all of a sudden the XR500 crashed. No internet, so I rebooted the XR500 and the internet was back op again. I am hoping the crashes are less frequent but this is really getting rediculous. I will wait again for a new update to the beta firmware as it looks like there will be no further updates after .66.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, I have been very busy and have not had a chance to perform the firmware flash. I am still having issues as it does disconnect every couple of days. I will do this after the holidays.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
9 | |
9 | |
6 | |
4 | |
2 |
