×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
upnp error
Guru
Re: upnp error
What is the Mfr and model# of the Internet Service Providers new modem?
@faruk_prlk wrote:
Hello, a new modem has arrived, I have installed it, what should I do now?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 51 of 65
faruk_prlk
Guide
Re: upnp error
TP link w9970
Message 52 of 65
faruk_prlk
Guide
Re: upnp error
what should i do on this page
Message 53 of 65
Netduma-Fraser
NetDuma Partner
Re: upnp error
Switch NAT Filtering to Open
Message 54 of 65
faruk_prlk
Guide
Re: upnp error
Message 55 of 65
Guru
Re: upnp error
If you can't get router mode working with the XR router, you might try bridge mode on the TP-Link modem:
https://www.tp-link.com/au/support/faq/2728/
@faruk_prlk wrote:
TP link w9970
Message 56 of 65
faruk_prlk
Guide
Re: upnp error
Message 57 of 65
Netduma-Fraser
NetDuma Partner
Re: upnp error
Did switching the NAT to open work?
Message 58 of 65
faruk_prlk
Guide
Re: upnp error
I did not add
Message 59 of 65
faruk_prlk
Guide
Re: upnp error
I'm getting an error on Xbox when Nat is on, so I turned it off.
Message 60 of 65
faruk_prlk
Guide
Re: upnp error
It's fixed now, no problem
Message 61 of 65
faruk_prlk
Guide
Re: upnp error
There is something I really want to ask, can you show what internet settings you have done on the xr device?
Message 62 of 65
faruk_prlk
Guide
Re: upnp error
Message 63 of 65
Netduma-Fraser
NetDuma Partner
Re: upnp error
For internet settings you don't really need to change anything else, it won't have an impact for you in game
Message 64 of 65
Guru
Re: upnp error
You can check this thread of some settings I use for my XR router:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR1000-Firmware-Version-1-0-0-64-R...
Message 65 of 65
Discussion stats
  • 64 replies
  • 1653 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
