- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
S8000 switch (gs808e)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear Sirs,
I have successfully updated the firmware from version 1.0.1.6 to 1.0.2.3
now I can't update to the latest firmware (v1.7.1.0) because when I start the update the process stops and the following message appears:
"file image (.bin) is not correct"
Why?
I would like to find the solution to the problem and update the "S8000 switch" to the latest firmware
on my pc there is Windows 7 64bit
My browser Is Google Chrome.
I await suggestions.
Best Regards
Andrea
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I solved the problem.
The switch is now updated to the latest firmware (v1.7.1.0)
The antivirus was blocking the update so I had to disable it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: S8000 switch (gs808e)
Try going to an intermediate version like the 1.7.0.6
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have already tried all versions 1.7.x.x but I always get the same message: "the image of the file is not correct" and the switch does not update...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, obviously I extract the file before the update but the switch does not update
I had no problems with firmware v1.0.2.3
I cannot understand why the switch does not accept firmware from version 1.7 onwards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What antivirus was blocking (might help others)?
You can mark it solved and it might help others with this issue.
Glad it worked!
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
