Orbi WiFi 7 RBE973
Reply
AC2350 Nighthawk X4 Smart WiFi Router (USB 3.0 Backwards Compatibility for USB 2.0 Printers
Blues_sLr
Dear Sir,
We are looking forward to buy the AC2350 Nighthawk X4 Smart WiFi Router 802.11ac Dual Band Gigabit Model number version: R7500 , but wanted to  know if the USB 3.0 ports are backwards compatible to USB 2.0 as we wanted to use a HP LaserJet M1005 Multifunction Printer(CB376A)  attached as network printing device in the WINDOWS 7 OS.
Kindly advise us on the same at earliest. Thanks and Regards.
Message 1 of 5
Accepted Solutions
NightOwl326
Luminary
Re: AC2350 Nighthawk X4 Smart WiFi Router (USB 3.0 Backwards Compatibility for USB 2.0 Printers
Message 2 of 5
All Replies
NightOwl326
Luminary
Yes it is.
Message 2 of 5
Blues_sLr
Thank you very much (:
Message 3 of 5
Please reconsider your purchase decision and, if set on Netgear equipment, look at models other than the R7500.
The product is "abandonware" at this point.
Message 4 of 5
Blues_sLr
Noted your kind guidance, will u please suggest a best model number considering its WiFi range as in very large homes type, g/n/ac.. Specs same or higher than the above mentioned price range not costlier than the above mentioned. Thanks.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2778 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
