- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Add additional router to R6080
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm attempting to add an additional router to my R6080 and am having no luck.
I want to add an Asus to it and I need the Asus to be plugged into the Netgear. The Asus will run behind a VPN while the Netgear will not.
When I plug the Asus into the Netgear I cannot get an IP for it and it doesn't even get recognized by the Netgear. But if I plug the Asus into the cable modem and the Netgear into the Asus it works just fine. But then both routers would be behind the VPN and that's not what I need.
I've checked the settings multiple times and I've searched but I still haven't been able to find what I need to do.
Any help would be greatly appreciated.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Add additional router to R6080
I would start by reading this:
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
In essence, you are trying to do something that "breaks" your network. You can't just string two routers together.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
