Orbi WiFi 7 RBE973
Reply
nighthawk r7500
genes161
nighthawk r7500
Message 1 of 5
Guru
Re: nighthawk r7500
Are you using it in access point mode?
Message 2 of 5
antinode
Guru
Re: nighthawk r7500
> How do I make dynamic dns clickable?
   Is the R7500 configured as a wireless access point?
      https://kb.netgear.com/26765
   I don't see DDNS in that list, but I'd expect to.
Message 3 of 5
genes161
Re: nighthawk r7500
No. But that was the problem, the access point mode, thanks.
I have two routers after my Nighthawk as accespoints. How can I get around this problem?
Cause I want to take control of my homenetwork when I am away on holiday.
Message 4 of 5
antinode
Guru
Re: nighthawk r7500
> [...] How can I get around this problem? [...]
   Which problem?  If you have only one external/public IP address, then
what did you expect DDNS on your WAPs to do for you?
   Note that "Remote Management" _is_ on the disabled-features list.
If you want to access the management web server on a WAP, then you
might want to configure port forwarding on your main router to allow
access to the WAP from the outside world.
   I'd pick non-standard external ports, like, say, 4581, 4582, ..., and
ensure that the "admin" passwords are non-trivial.  Note, too, that on
most models (firmware versions) you'd need to use HTTP (not HTTPS), so
the security would be less than ideal.
   And, of course, because the LAN IP address for a WAP would appear in
the port-forwarding rule, you'd need to use something like Address
Reservation to ensure that the LAN IP address of the WAP is fixed.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 838 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
