Orbi WiFi 7 RBE973
Reply
Admin Account
FIDI_G
Admin Account
Hey thanks in advance. I have 3 questions around security for my RAX45 Router:
1) The model section above does not let me select the RAX45 — Nighthawk AX6 6-Stream AX4300 WiFi Router. So technically I dont think I'm posting these questions to the right group. Hopefully it's not important.
2) I cant figure out how to remove or rename the admin account. I would like to create a new admin account and name it something other than "admin" Basicly I only want one admin account and I want to name it something else. Is this possible?
3) I use a ddns service and I find it very wiered that if I type in the ddns address I get prompted to log into my router. How do I disable this externally? I would like to log into my router when I'm at home (internally) but not expose this when I'm outside of my local network. That with a default admin user account of admin doesnt that potentially make it easir to hackinto?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
antinode
Guru
Re: Admin Account
> [...] So technically I dont think I'm posting these questions to the
> right group. [...]
      https://community.netgear.com/t5/x/bd-p/en-home-routers-nighthawk-wifi-ax6
> [...] I only want one admin account and I want to name it something
   Generally no, not on Netgear consumer-grade routers.  (There might be
some exceptions, but if it's not mentioned in the User Manual, I'd infer
that it's not possible.)
> the ddns address [...]
   Do you "type in" some "address", or a [D]DNS _name_?  (Or does it
make no difference?)
> [...] I get prompted to log into my router. How do I disable this
> externally?
   Where, exactly, is the web browser where are you doing this?  Some
computer/device on your LAN?  Have you tried doing it _really_
"externally"?
> [...] I would like to log into my router when I'm at home (internally)
> but not expose this when I'm outside of my local network. [...]
   First, verify that the router actually does "expose this" to the
outside world.  It might be "helping" you more than you'd expect.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for
"remote access" and/or "Remote Management".
> [...] with a default admin user account of admin doesnt that
   That'd depend on your choice of password.
   When it comes to ease of guessing, what's the practical difference
between:
      user = <other_name>   pass = <short_pass>
and:
      user = admin   pass = <other_name><short_pass>
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 575 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
