- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
BASIC SET UP
- Mark as New
- Bookmark
- Subscribe
- Permalink
BASIC SET UP
I will keep this simple so where to you plug in the above router in your/my house.
My house uk BT line comes in to socket then what?
Because when i plug mine in i can get no internet?
Yes phone line works
Yes all services on
Is this not copatable with the UK network?.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BASIC SET UP
I would review the installation guide to see how to setup and connect the router:
https://www.downloads.netgear.com/files/GDC/RAX120/RAX120_QSG_EN.pdf
Turn off and unplug modem.
Turn on computers and rest of network.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products.:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BASIC SET UP
From what i can work our i need a modem for some reason there isn't one built in which to my surprise no one says or on the box
I have a VDSL / DSl connection which by my guess is about 80% in UK and i'm not the only one with this problem
so basically bit of a waste of money
supposedly one of the best routers out and i need a £24 modem to make it work pretty **bleep** !
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BASIC SET UP
Sure is, but you need the right equipment and settings.
Is this the same issue as the one you posted here?
nighthawk why - NETGEAR Communities
The details there are a bit different. So there doesn't seem to be much point in dealing with this conversation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: BASIC SET UP
The "reason" is that you bought a router. This is not the same thing as a modem/router.
You can't expect boxes to say what they don't include.
Your ISP almost certainly explains what you need. It might even offer to sell you the hardware. Most do, albeit at a price.
