Orbi WiFi 7 RBE973
Reply
Double NAT
rwxrwx
Guide
Double NAT
To resolve a double NAT issue I toggled off the router portion of my combo router/modem unit.  Now I can't access the modem to change settings using the IP address 192.168.0.1, 192.168.1.1 nor the web addresses such as routerlogin.com.
How do I access my combo when the only method by which to do is via wifi?  I will add that my PC is hardwired via ethernet and not wifi and is what I use to access the unit.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 5
Accepted Solutions
Guru
Re: Double NAT
try 192.168.100.1
That's the default address for the modem.
Message 2 of 5
All Replies
Guru
Re: Double NAT
try 192.168.100.1
Message 2 of 5
rwxrwx
Guide
Re: Double NAT
Thank you!  That worked!
I have one other concern though.  Most of the settings that were there prior to me turning the router off are now gone.  There a reason for that?
Message 3 of 5
Guru
Re: Double NAT
Not 100% but switching it over to modem only mode disables the router function. maybe its a component of modem only mode to reset the router back to defaults.
Message 4 of 5
rwxrwx
Guide
Re: Double NAT
Gotcha.  I had port forwarding set up and now I do not have access to that feature.  I'm going to leave the router off nonetheless.  I was having trouble with using Plex and hoping that resolves the problem.
Thanks again.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3127 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
