- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is it possible to forward more than one port to a single port? (Or, how can I do this?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone,
I have a service running on a port (let's say 9999). I can forward 9999 external to 9999 internal. But, what I would like to do is to forward anything that comes in on 80 or 9999 (externally) to 9999 (internally). Is there a way to do this with the R7000? So far, anything I've tried has caused it to complain that the port is already in use.
Thanks in advance for any help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
(2 or more) external ports - (1) internal port - (2 or more) IP address (this should work)
(2 or more) external ports - (1) internal port - (single) IP address (NO!!!)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is it possible to forward more than one port to a single port? (Or, how can I do this?)
Hi eric_bor,
Correct me if I am wrong. You wanted to open one port number for a service which will be used by multiple devices. If yes, you can configure it by changing the external port to a different port number and set the same internal port number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Close. The problem I'm trying to overcome is that I am able to access the port for this service when on my internal network or via Internet. But, at work, behind vpn, I cannot use that port, so I would like to allow *either* port 80 or port 9999 to go to port 9999. So, via port 80, go to 9999. Via port 9999, go to 9999 as well.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi eric_bor,
Please try to downgrade the router's firmware to v1.0.4.30 and check if you will get the same error message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
