- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
NETGEAR R7800 FIRMWARE v1.0.2.80 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR R7800 FIRMWARE v1.0.2.80 issues
@UniverseNet wrote:
I find that a second reboot makes is so the update doesn't take 2 to 3 hours to work well. Typically in the 2-3 hours after my last 3 firmware updates I had no Internet access. The second reboot dispenses with the delay.
Probably something else, but there is certainly no harm in that sort of move.
I step in to add yet another wrinkle. In the past, depending on the firmware version, Netgear has also occasionally specified a reboot before updating the firmware.
If I saw the above happening, and a failure to connect post flash, I would first see if a factory reset fixed it. (First backup the current settings.) If not I would also restart the network in the specified order.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That didn't help. The R7800 is crashing WLAN every couple minutes with the v1.0.2.80 even if it is not connectet to anything and even when you do a factory reset before and after updating firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear R7800 Firmware v1.0.2.80 contains BUGS
EXACLTLY SAME PROBLEMS and random REBOOT !!!
with firmware v1.0.2.74 or v1.0.2.76 or v1.0.2.78
R7800 reboots randomly after boot up .... works 2 minutes and reboot...
WIFI drops in AP MODE / unable to use AP MODE
R7800 v1.0.2.80 firmware always contains BUGS ...
Even with fresh and clean install :
Reset the router = push reset button for 10s... Still the same problem.
DO NOT UPDATE FIRMWARE v1.0.2.80 R7800
Back to firmware v1.0.2.68 and everything is OK again...
- Mark as New
- Bookmark
- Subscribe
- Permalink
HELLO
fyi 1.0.2.82 is out
https://www.netgear.fr/support/product/r7800.aspx#download
i'm gonna try asap
Bye
- Mark as New
- Bookmark
- Subscribe
- Permalink
Read this before you jump:
R7800 Firmware Version 1.0.2.82 | Answer | NETGEAR Support
Several features removed.
Note that starting with this firmware release (V1.0.2.82), the following features are no longer supported: ReadySHARE Vault, OpenDNS (Live Parental Controls), remote GUI access, and WPS PIN function. If you want to continue using these features, do not update the firmware.
Re: New firmware (V1.0.2.80) for the R7800 - Page 2 - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
TOPIC for R7800 v1.0.2.82 firmware issues HERE
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NETGEAR-R7800-FIRMWARE-v1-0-2-82/m-p/2078629
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
