Orbi WiFi 7 RBE973
Reply
NG Nhawk R6700 AC1750
renzandjo
Please help. I have NG NHawk 6700 AC1750 and I just tried to do the firmware update today 9/13 and the update would not complete and got errorrs and then I just lost all conectivity and it appearrs like i am locked out of the router, I can not do anythingg and there is no internet at all. There is only one light, the orange power just blinking. I have tried to unplug and reboot everytthing to no avail. I should have never done this update, can someone help me with this?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: NG Nhawk R6700 AC1750
sounds like you might have corrupted the firmware. in the future, i'd recommend not using the app to update with. I'd use a hardwired computer.
for the present, you can try recovering it using tftp.
 are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 6
All Replies
Guru
Message 2 of 6
kaclock
Came here because I'm having the exact same issue.
Message 3 of 6
renzandjo
thanks for responding.
Can you give me these instructions for a macbook pro running safari, chrome or firefox?
Message 4 of 6
renzandjo
Can you give me these instructions for a MACbook PRO  running safari, chrome or firefox?
Message 5 of 6
antinode
Guru
> Can you give me these instructions for a macbook pro [...]
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] running safari, chrome or firefox?
   A web browser is not really part of the TFTP recovery scheme.
   If you have trouble, then it'd probably be better to start your own
thread with your own details.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1190 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
