- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New firmware for the R7800 - v1.0.2.90
- Mark as New
- Bookmark
- Subscribe
- Permalink
This just in:
R7800 Firmware Version 1.0.2.90 | Answer | NETGEAR Support
Enhancements:
- Remove Funjsq for PR SKU.
Whatever that means.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New firmware for the R7800
PR SKU (country code PR) does apply products intended for the Chinese market.
1. Funjsq is a download accelerator that is embeded within the firmware.
2. Funjsq is from China. (Google funjsq or Funjsq.com)
3. Funjsq is enabled only if QoS is enabled.
Note: Funjsq was replaced by XunYou to PR SKU e.g. on the R6700AX (-> https://kb.netgear.com/000064298/R6700AX-Firmware-Version-1-0-10-110)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears to be related to qos - Still looking. At first I thought it was related to Java Script.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you own a router with a China SKU, like R7800-100PRS ? If not, noting to worry, no special handling required, because of the module isn't loaded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the R7800 works with out the EX7500 being online?
What is the distance between the 7800 and EX extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, the R7800 works, is online and speedtests give the same result as they did under firmware version .84. I gave the EX7500 a few factory resets. It didn't want to talk with the R7800 with WPS, but eventually a manual setup did the trick. They are now back to their old selves with a steady connection between 585-650Mbps. They're about 15 feet apart. The extender is hanging just around the corner in my hallway, so the only thing in between is a concrete wall / cardboard filled door, depending on how the signal travels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well 15 feet maybe too close and 30 feet would be a starting point. However with concrete in the mix, maybe something thats causing problems.
Might try the extender maybe 5-10 feet farther away if you can...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just updating this to let everyone know that NG has fixed the GUI update MD5 error seen on this version of FW. Users can try to check for FW updates again using the routers web page and if the GUI is reporting needing updating, proceed and it will complete successfully now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wired speeds are good.
WIreless 5Ghz is great. Have 160Mhz enabled on the R7800 connected with a ASUS GT-AX11000 in wireless bridge mode:
Smart Connect enabled on manual channel 1 and 40. Beamorming and MIMO and HT160 enabled. CTS 2347.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you happen to use Traffic Meter on this version of FW?
Just curious...I'm using on my R7800 and it's enabled for No Limit and I'm not seening any updated Traffic specs being updated in this section. All zeros. I've had mine on since earlier this week and theres has been lots of data flow since then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please...let me know what you see...I'm not seeing any thing but zero's.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems to be working as expected.
A full record of today's activity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting. Same on the Nighthawk app? My app shows same, zero data.
I guess I try a factory reset though a few have already been done since the MD5 Error for the GUI update problem appeared.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How is Traffic Meter configured on your router? Mines set for No Limit and that's it. What I normally set with other routers I test with and data collects.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok.
I just disabled TM, rebooted router, then re-enabled. Still not seeing anything..Odd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
