Orbi WiFi 7 RBE973
Reply
Nighthawk VPN not working
hengifa6
I can connect to the routers VPN just fine. Local addresses work. Internet, or outside access does not. It is configured correctly for "both internet and local" Any suggestions?
Message 1 of 2
Guru
Re: Nighthawk VPN not working
What model router do you have?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 705 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
