- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Permission denied when trying to create folders and files on a USB drive using ReadyShare / Samba.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded my router from a R7000 to a R7800. I used an external USB drive with the R7000 formatted with ext4. Everything worked. The drive is detected and mounted on the R7800 and I can browse and read the content, but I can only write to existing folders and new create new folders using the ReadyCloud web interface. When I try to create new folders from my laptop through smb / Samba I get a permission denied error message and when I try to add files to a folder created with ReadyCloud I get the same permission denied message This regardless of what kind of device I use to connect with, Windows / Linux computer, my phone or a laptop.
Any idea how I can troubleshoot and possibly fix this? If I have to I can back up the data and format the drive again. I am using Voxel's firmware.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Samba server is one of the components that is improved on Voxel's firmware and I see better transfer speeds than I ever saw on the R7000. Thanks guys!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Permission denied when trying to create folders and files on a USB drive using ReadyShare / Sam
Was fine until you said you were running non-stock FW. (which is not neccessarily a bad thing).. But I have no way to reproduce the behavior.
A guess. Yes, move the data, format on the new router and see what you get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Like I have said before. IMHO the only way to have reliable network file support is with a dedicated NAS. Always have been and I suspect will continue to have issues with USB file support on a router. Routers are meant to route and support networks NOT all the other garbage such as USB file support that doesn't work reliably if at all. I learned the years ago and things do not seem to have improved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
