Orbi WiFi 7 RBE973
Reply
Port forwarding dont open ports
Edvard_Korsbaek
The correct model, is Nighthawk(R) X4S R7800.
I have a static IP adress, and my netbox is setup in bridge mode.
I have setup two port forwarding rules for port 88 and port 1088.
Even if i disable my firewall (Eset), i get this result from https://www.yougetsignal.com/tools/open-ports/
Port 88 is closed on 212.37.152.80.
BTW - I have setup my firewall to accept acces on port 88/1088, but no firewall must be the ultimate check.
This is the main problem. I have tried to solve it over the last weeks, and one advice i got was to setup the static IP correct,  so it uses the static ip instead of using the "Get Dynamically from ISP", but if i use the values from "Connection Status" , i get no internet connection.
Best regards
Edvard Korsbæk
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: Port forwarding dont open ports
> [...] my netbox is setup in bridge mode.
   What is your 'my netbox"?
   Ok.  What is listening at those ports on the system at
"192.168.1.15"?  Web server?  Something else?
> [...] 212.37.x.y [...]
   Is that the WAN/Internet address of the R7800?
> [...] one advice i got was to setup the static IP correct, [...]
   Probably not a good idea.  Your ISP probably knows what it wants
better than you do.
      https://community.netgear.com/t5/x/x/m-p/1859106
Message 3 of 5
All Replies
Edvard_Korsbaek
Correction - If i setup the static IP, it works, but painfully slow.
Message 2 of 5
antinode
Guru
better than you do.
Message 3 of 5
Edvard_Korsbaek
I have a fiber solution from a ISP, and the 'Netbox' is the place, where the fiber ends, and i have my connections.
Its a web server. it works like a charm on 127.0.0.1
Yes
better than you do.
Message 4 of 5
Edvard_Korsbaek
The problem is the firewall - It works with the firewall set to 'Allow all', and thats solvable.
Thanks for your hints including the link to another rhread. It was usefull!
Best regards
Edvard Korsbæk
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
