- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 2.4ghz not working but 5ghz is fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 2.4ghz not working but 5ghz is fine
@houseofbugs wrote:
@fishbone wrote:Sorry, this may have been covered before but I am hesitant to re-read 30+ pages...
I realize starting with a fresh factory set is ideal, but...
Can I flash 1.0.4.28_1.1.64 and the settings from 1.0.6.28_1.1.83 survive?
Or can I save the 1.0.6 setting, flash and factory reset 1.0.4... and restore settings from that file?
Thanks.
Factory reset and manually re-enter your settings. I wouldn't recommend using your stored config file.
Correct. Netgear introduced major changes to the configuration file format between 1.0.4.30 and 1.0.6.28. Files from these two versions are incompatible and should not be interchanged.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you read one of my previous posts, I have a Linksys EA9200 (AC), that also is dropping the 2.4GHz channel. Although with the Linksys, it doesn't drop it nearly as often as the Nethear R7000 does, I would say maybe once a month or once every other month.
Which is why I posed the question if it may be the chipsets being used in these AC routers. I haven't been able to determine what chipset the Linksys uses. I read that the netgear uses the Broadcom Xstream chipset, but I don't know if there are different versions of that chipset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi J_Gonzalez, someone from our support team should have reached out to you today to gather your config file. Please let me know if that didn't happen. Thank you so much for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, thank you for the description of the physical environment. I've shared that with the engineering team. That will help us understand what a noisy environment looks like to a customer and not just in a lab.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After weeks of triying to get the netgear firmware to work, I gave up and installed tomato. it seems to be working ok thusfar, one day.
when and if netgear gets their act together i will revert back, I have a feeling that I will be using tomato for a long time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I was going to sit down and actually downgrade, but...
If I recall correctly the VPN component was upgraded in 1.0.5 to support OpenVPN TAP, which 1.0.4.30 doesn't - so rolling back is not workable as we've already made that switch and some clients only support TAP.
Bottom line - I need the fixed firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hoi,
I have problems,
since januari I had version 1.0.6.0.30 and it was ok, but since a few days the wifi is not good, I must power off/on.
Which version is the best for now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, it has been about a month since this post. When will 1.0.6.40 be released to the public? Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
The beta release was v1.1.10.167514, so I imagine any general release that comes out next will be 1.1.x.x
As an update, it's been 2 weeks since I went back to 1.0.4.28_1.1.64, and so far no problems. With the other versions, the problem would appear after 3 or 4 days. So looking good so far.
As I mentioned before, the one thing I did do different this time was to do a hard reset of the router after i updated the firmware, then reconfigure. When I tried the other versions, including the beta version, I wasn't able to reset the router. So I don't know if all the other firmware versions were still buggy, or if a hard reset was required.
if I had the time, I would install the beta firmware then do a hard reset and see if that's stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using firmware version V1.0.5.48_1.1.79 and not having any problems with that. It has been over 3 weeks since I rolled back to this version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem with version V1.0.6.28_1.1.83
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone, I apologize again for the delay. I talked to the engineering VP responsible for this software and the hope is that we can have updated beta firmware available mid next week, with a production version to follow. I know this is taking longer than I committed, but I'm doing my best to keep the issue prioritized within the engineering team. Thank you for your patience with us.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have used firmware version V1.0.5.48_1.1.79 for 4 month when same happened 1st time to me 2 weeks ago. I have found and read most of the posts here (thanks for that) and returned back to 1.0.4.28_1.1.64, with no problems so far. I could preserve most config data except port forwarding, which needed a painful 20 minutes to manually set up again, without factory reset done.
The sad thing around this is, that when the unit was 1 month old, I have upgraded to V1.0.5.48_1.1.79 (to a well known bad firmware version for all others involved) but realized that I have lost portt forwarding setup. Having been still in support I wrote this to the support. As you can expect the existing issue with 2.4 GHz connection was not even mentioned by them. Of course, the config loss due to firmware upgrade is still not solved which is a joke.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I gave up on Netgear releasing a stable firmware, from my trusty 3500L, wndr3700 v1 and some older ones to my new paper weight R7000 (thank you netgear), btw I still have all my netgear stuff, yep never know when you going to need it, I purchased my last netgear product, if I'm going to spend over $150 on any product I expect a level of support, I understand hardware fails and I am ok with that, this wasn't a hardware failure unlike some of you like to believe, this was caused by the release of buggy firmware.
Been using Advance Tomato and is ok thusfar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just so there's no confusion...
It's quiet because there is nothing else to be said about the problems right now, not because we lost interest in the update...
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me, it's been a month since I rolled back to 1.0.4.28_1.1.64 (did a hard reset after installing that firmware) and so far we've had no problems. Normally we would have the 2.4Ghz channel choke after 3 or 4 days. So this tells me that it's definitely a firmware issue, which I believe is the position of Netgear.
Since the office needs are simple, I don't feel that I'm losing any features. When netgear does finally come out with the latest working firmware, I would consider upgrading right away if there were performance improvements, otherwise I may wait a while to see how things settle down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since today my wifi is bad and I had version ....28 , so I had a restart and put the wifi button on and off, but all my port forwarding was disapeared! when I look in the router.
What is going on Netgear????
We are still waiting for a solution.
My cams are suddenly very slow.
What must I do now, Is the version Tomato an solution?
The version....28 was stable for about 3 weeks. What a mess Netgear!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
We depend on the enhanced OpenVPN implementation of 1.0.5+ which made things easier on mobile, so 1.0.4 is not an option unfortunately.
I am somewhat baffled why it takes Netgear so long to fix known show-stopping issues on a high end product.
There seem to be organizational issues not being able to prioritize it with engineering.
This month is bad timing for experiments on a critical component in our network, but if we don't get a solution in the coming weeks I may give Tomato a shot.
That said, I selected this router to have a reliable high end device that we can count on and generally don't have to think about, not to have a gadget to tinker around with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And when doing a factory reset, instead of reconfiguring everthing afterwards, is it ok to just use my settings backup to get everthing back right away or its not recommended?
Thx
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a broke of my power 230V all my cams have an other port. I have versionV1.0.4.30_1.1.67
Pff I do not know what I must do.
Netgear what is going wrong . It was a expensive router. and I hear nothing from you.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
