Orbi WiFi 7 RBE973
Reply
R7000 AC1900 Restarts when wifi downloads exceed 1mb per second
My r7000 has been restarting itself when downloading seems to exceed 1mb/s  I know this is the problem because I've throttled the download speeds to below a mb and it works ok.  Can this router not handle the load?  Happening on 2 and 5 ghz, I have 10+ devices connected.  Doesn't seem to happen on ethernet connection.  Any advice, recommendations, best alternative firmware?
Thanks
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 13
Accepted Solutions
Re: R7000 AC1900 Restarts when wifi downloads exceed 1mb per second
It's the firmware, just loaded ddwrt, works fine now.
Message 9 of 13
All Replies
DarrenM
Sr. NETGEAR Moderator
We released a new firmware see if that changes anything.
https://kb.netgear.com/000060566/R7000-Firmware-Version-1-0-9-64-All-Regions-except-China
DarrenM
Message 2 of 13
Nope, just updated and tested, still reboots....
Message 3 of 13
twitchy
Well. No such luck.
Seems like the device still wants to continually reboot after 2-10 minutes of playing games and streaming.
Message 4 of 13
twitchy
@Avalanche2121
I resolved this issue with a downgrade to 1.09.34 last night.
Everything is working as expected at this point (including my Circle device).
I will attempt an upgrade to 1.09.42 tonight, and see how that works out, but I recommend the downgrade at this point for you as well, to see if that helps at all.
Message 5 of 13
No deal, still junk lol
Message 6 of 13
twitchy
Same boat it seems. 1.09.34 worked for a few days. And just had repeat disconnects... This is not fun 😞
Message 7 of 13
JWS9518
Apprentice
DarrenM
Darren
Your new firmware is garbage..with constant random reboots and connection issues. .42 is the last firmware that worked well.
Message 8 of 13
Message 9 of 13
twitchy
Have you had any issues since switching to ddwrt?
Message 10 of 13
I have had some setting and config issues, as i am using this router as a bridge now.  However, the original problem of restarts due to wifi downloads has been resolved.  I have downloaded multiple items at high download rates and the router has stayed on and not disconnected/restarted.
Message 11 of 13
Can't speak for any of thre FW revs since 1.0.9.42.  Stability has not been an issue in my 5 years of R7000 ownership.
The router has never restarted under any circumstances regardless of the load put on it's interfaces (wired or wireless).  While this could be an issue with FW above .42 (I have no experience with them).  The hardware is not inheriently faulty, anyone having stabilty issues, unexpected restarts, etc, should look at their FW and how it was loaded.
The most common cause of instability and restarts (at least with earlier revisions) is corrupt FW loaded using auto-check and update, automatic update or using Genie via a wireless connection.
Message 12 of 13
UPDATE:  I managed to brick this router while messing around trying different things.  I re-loaded the netgear stock firmware via the TFTP recovery method and the router seems to be running much better, handling lots of traffic with no reboots.  It may be worth a shot if your at wits end.  The procedure can be found here: https://community.netgear.com/t5/General-WiFi-Routers-Non/Guide-How-to-quot-unbrick-quot-your-WGR614...
It may take a few minutes to complete then it restarts itself, i had to reset it after as well to get it up.
Good luck, Cheers
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 5126 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
