Reply
R7000 power consumption
junyan2000
Tutor
Is a 12V 3A adapter sufficient to power Netgear R7000?
The oem charger is rated at 3.5A, but I cheaped out and bought a R7000 without adapter (since I have some spare 3A chargers). I wonder if the extra 0.5A makes a difference.
Message 1 of 3
Guru
Re: R7000 power consumption
Maybe not too bad however over time could see problems at the power adapter or at the router. I recommend finding one that has same specs to be sure. I find mine on Amazon.
Can try one out and see how it works. Brick may feel a bit warmer.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
Guru
If you're not putting it under a heavy load and using the usb ports, you might be fine. All you can do is try it. If its not stable, then you might need to spring for a little bigger one.
Or turn down the 2.4/5ghz broadcast strength and make sure not to use the usb. Those would save a bit of power.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 483 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
