- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7800 speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's a lot of tech speak about this router, lots of specs about what it's able to do.. but it does seem to do it for me..
Is there a simple configuration for this thing to just do what it says, out do i need to go back to school to get a freaking degree in this stuff..🤕
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The S7's max wireless connection rate is 867Mbps. Your throughput speed will be half of that. So, if you are connected at 867Mbps, for instance, your throughput speed will be around 400Mbps, only if you consistently get your max connected rate. Wireless is susceptible to your environment (home construction, interference , router placement, etc). Try different 5ghz channels, to see if you can obtain a more consistent connected rate. I would also try disabling MU-MIMO manual page 72 and re-test. Then try disabling beamforming and then re-test. If HT160 is enabled, I would disable and then re-test.
You could / should also try upgrading the router to the latest and greatest firmware. When you upgrade your router to the latest firmware (or to any firmware level), save yourself the grief and reset the router to factory default and reconfigure the router from scratch.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7800 speed
So, overall problem solved ... Thanks..
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
