- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look logs
- Mark as New
- Bookmark
- Subscribe
- Permalink
R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look at the logs?
I changed firmware. I thought I had the newest but the site said there was a newer firmware so I went to go upload it and the router told me the version I had was more up to date. Regardless of that I did an update. Okay.... so at first when I logged into the router the other day I saw a dev device connected and an unknown. Soon after that my connection was killed and I had to log back in. When I did those were gone. So today I log in and started recording the logs. Boom, my internet goes out and connection to router dies. What's weird is when I sign back in the NTP server had changed to another time zone. Super odd. Anyways. I normally see the false positives. But I actually have flood attacks. Also, whenever I go to a site it won't load the first time then it loads. It's odd. Can someone look at my logs? I have a new orbi I should just put in. Also thinking about PFsense or if the orbi has bitdefender I'll use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7960P Changed firmware due to security concerns. Now I'm even more worried. Can someone look
Do you have any Apple devices, if so, disable the WiFi Private IP Address feature on these devices while at home. This feature when enabled will appear as a "DEV" or unknown device on the routers web page. This feature randomizes the MAC address on Apple devices. Thus causing the router to display a unknown or DEV host name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
V1.4.3.88_1.3.50
BASIC
Getting weird site not secure
CM2000 Netgear is modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
What site is this and on what device are you seeing this on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is he exact message?
If that is in your browser, try another one.
Browser makers keep changing their approach to security. Something that works one day can fall over after an update.
Another possibility is your operating system, Windows, for example, tries to defend us from the cruel world and sometimes gets overprotective.
Did a bit deeper to see what is going on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you explain more about the Disconnects?
Is the router disconnecting or devices?
