- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 - WIFI Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need some help on increasing the wifi speed on this router. I upgraded my broadband to 1 gb, and it's pushing over 900 mb when directly connected to the modem. Connect through the router, and I am lucky to get 300 mb. I have seen other people have the same issue, and it's looks like I need to back rev the firmware to correct this issue. Just wanted to verify that this is really the fix, and how much more throughput can I expect. I have not reset to the factory options, I have read that this really doesn't do anything to correct the problem. I just upgraded to the latest release of the firmware that was just released a couple of days ago, no change. Anyone who has had this problem and corrected it, I would like to hear from you. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Its tough because many things impact wifi speeds.
It could be the device you're testing on.
it could be interference.
it could be qos, traffic monitoring, access controls, parental controls.
I'd start with disabling the 4 above. They're not recommended at speeds >250mbps.
if that doesn't fix it, try just a simple factory reset and reinstall manually. (not from backup).
Try those before downgrading.
What device are you testing with?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
