Reply
R8000 not detected internet connection
Ericglo
Follower
Router worked fine for 3 months until last night. I have reset router and modem but it did not help. Called cable provider and was told wifi is the problem since cable Tv works fine Ethernet hardwired. Not tech savvy not sure what else to try.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Guru
Re: R8000 not detected internet connection
We need more info.
1. what modem/gateway is it connected to?
2. Firwmare on the router?
3. What are the led's on the router showing? (color, blinking, etc)
4. Do wired devices have issues? Only wireless?  Is it saying "connected, no internet". What actual issue is going on/happening? We aren't there to see so the more details you can give us, the better we can help.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 137 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
