- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 router connected with BT FFTH
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I need help in setting up my R8000 router with a BT hub after we have just had installed FFTH. The Bt engineer has connected the Fibre to one of my 4 ethernet connections on the BT hub, and enabled a passthrough on the hub
I have then connected the R8000 to the BT hub via ethernet, but where do I connect it to , the yellow or black ports on the R8000. I have tried the yellow one and I get a solid amber light on display for internet - so that isn't working
I cant connect to the R8000 via the app to allow me to set up the PPPoE which I then think would allow me to connect the Black BT port to the Black R8000 port, but I cannot get the app to complete this
The BT Hub is working as expected, and I have other ports connected to PC / BT whole home discs, which is what I want to remove and replace with the R8000
Been at this for 2 days and cannot fathom the connections out, do I need to alter any other settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 router connected with BT FFTH
Has to be the Yellow WAN port in back of the R8000.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try the R8000 in AP mode with out IP Pass thru on the ISP router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI FURRYe38, I have tried the set up as you have suggested, but I still get an orange light on theR8000 unit for internet connection, so I don't believe I have a live internet connection, the light occasionally flickers like its trying to make a connection but nothing happens
Any other suggestions would be most welcome
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Has a factory reset and setup from scratch been performed since last update?
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi againFURRYe38, can you please explain in simply words how I get this R8000 into AP mode, when I cant connect to it
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
And, of course, the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
