Orbi WiFi 7 RBE973
Reply
R8000P Roll back firmware
Dpregs
Hi all,
I recently did the update on my R8000P and now my network is SO unstable.  Some devices refuse to connect.  I have restarted everything, rebooted, anything and everything I could think of.  I updated to Firmware Version V1.4.1.64_1.3.25, how do I find the previous version?  I have gone to downloads and then previous versions, but when I try to download any previous version chrome tells me it is unsafe and even if I download it, the zip file says it is a fragment.
any and all help appreciated!!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: R8000P Roll back firmware
> I have attached a pic of what it looks like after I unzip it.
   Ok.  "Recovered File Fragments" is what Windows File Explorer says
about any file named ".chk".  It's meaningless.
>       https://community.netgear.com/t5/x/x/m-p/1721037#M124018
   Did you read it?
Message 4 of 5
All Replies
antinode
Guru
> [...] when I try to download any previous version chrome tells me it
> is unsafe [...]
   What was the actual error message?  How, exactly did you get it?
   As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] and even if I download it, the zip file says it is a fragment.
   A file does not "say" anything.  What, exactly, says what, exactly,
when you do what, exactly?
Message 2 of 5
Dpregs
Thank you for the reply, I have attached a pic of what it looks like after I unzip it.
Message 3 of 5
antinode
Guru
   Did you read it?
Message 4 of 5
Dpregs
Thank you for the help, I did read it, but I guess I missed it.  I read it again and tried uploading it again.  This time it worked.  Your quick response and help is appreciated!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1792 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
