Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Re: R7800 Firmware V1.0.2.92 update messed up readyshare
- Mark as New
- Bookmark
- Subscribe
- Permalink
2024-05-22
03:36 PM
2024-05-22
03:36 PM
Newbie on routers but had this one a while now. And have learned a little bit not much.
I am not sure where to or how to post this. So if wrong please forgive me but I need help.
This new update (.92 firmware update), I Lost the ability to set device priority. All show low even if I change it. It does not hold. I also cannot see bandwitch by device anymore etc. I have roommate/s and I need to be able to set my cams to high and have control of things. My device stutters on occasion because because I cannot set equal bandwith or set priorities. I am upset about this. I have many smart home devices and oh what a job to default. I remember having to roll back firmware and I was able to get the features mentioned above back but I defaulted and had to add all devices again. I have it set to not to update on its own. I am not sure if I manually did it arrrg. I must have thinking those issues were resolved.
I am not sure if the QOS is ticked makes that happen but it is. I thought it did? But it's on.
My questions are:
Can I save devices-back up settings then default router, upload the older version, then reinstall my back up-device settings and still keep the older firmware version or will it change it back to( .92 the newest I am trying to replace? ) I dont want to do that. Uuug I have 43 or more devices I hope I do not have to start all over again. It is soooo much work.
**Also, will rolling back to the previous 1.0.2.90 vers give me those capabilities back or do I need to go to an even older vers. ?
I forgot what version I used before, thinking it just happened with the .82 vers.
And lastly, were can I easily find older versions for R7800 to download?
I must have manually updated it thinking perhaps the issues were fixed. Angry at myself..arrrg.
Thank you for all your help in advance.
My questions are:
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2024-05-22
03:38 PM
2024-05-22
03:38 PM
Agree. 😞 I want yo use my ready share but I am dealing with another problem. I think I will fix both by rolling back. Just wish we did not need to do all this.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2024-05-23
03:04 AM
2024-05-23
03:04 AM
If you want to catch the attention of the Netgear team, it is usually better to start a new conversation rather than hitching a ride on one started 18 months ago and last visited six months or so months ago.
Not that new. It landed in October 2022.
Where are you trying to set this?
Message 3 of 3
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
